10
I was looking at some book of system programming. It mentioned to use a variable TZ with a colon separated list which is used from /usr/share/zoneinfo. Probably the book is a bit outdated.
I checked on my Ubuntu system
/usr/share/zoneinfo/Asia$ file Oral
gives following output
Oral: timezone data, version 2, 14 gmt time flags, 14 std time flags, no leap seconds, 51 transition times, 14 abbreviation chars
I tried opening it in vi but the text could not be read. I also tried reading /etc/localtime but here also it could not be read.
  1. How can I basically read above type of files?
  2. Where is TZ environment variable defined in Ubuntu 10.04?
poolie
  • 9,358
Well, it depends what you want to read it for?
Almost all programs just rely on $TZ being set in the environment or /etc/localtime being a link to a timezone file. The C library will then automatically arrange for eg localtime() to return the correct time.
1) How can I basically read above type of files
zdump -v /etc/localtime will show you what's inside the files.
These are compiled files not meant for humans to read. apt-get source tzdata will give you the source they come from.
2) Where is TZ environment variable defined in Ubuntu 10.04
It is not set by default. Instead, /etc/localtime is a copy of the relevant zoneinfo file, and /etc/timezone is the name of that zone.
You can change them with sudo tzconfig or through the GUI.
You could set it in for instance ~/.env if you want a different personal default for yourself.
poolie
  • 9,358
