How can I minimize the Terminal window using a command? For example: I use the clear command to clear the terminal output, which command can I have to use to minimize the terminal window?
Asked
Active
Viewed 7,300 times
23
24
You could use this command:
xdotool windowminimize $(xdotool getactivewindow)
You can change xdotool getactivewindow with a specific window that you would like to minimize.
xdotool wouldn't be installed on Ubuntu by default.So run the below command to install xdotool package.
sudo apt-get install xdotool
Avinash Raj
- 80,446
Mihai
- 1,674
If you are using the byobu terminal, you can press F6 to detach from the current session. This will have the effect of closing the window, but continuing to run byobu and all its subprograms in the background. To reattach to that session, just run byobu again as you normally would.
gabkdlly
- 1,114
