I have installed ddclient on my server and it seems to work. However, I get these warnings in my syslog:
nochg: No update required; unnecessary attempts to change to the current address are considered abusive
Obviously, ddclient fires the update even if the IP address check returns the same address as last time. How can I change this to have it do the update only if the address has actually changed since the last run?
Here is my /etc/ddclient.conf, with some information redacted:
daemon=300
syslog=yes
verbose=yes
protocol=dyndns2
use=web, web=dns.loopia.se/checkip/checkip.php, web-skip='Current IP Address:'
server=dns.loopia.se
ssl=yes
login=<redacted>
password='<redacted>'
<redacted>
Kalle Elmér
  • 9,216
ddclient uses a cache to check if your public IP address changed from your last report.
Only if it changed it will send the new one.
You might have an error in your cache file. Remove it to let ddclient create a new clean cache file.
 sudo rm /var/cache/ddclient/ddclient.cache
davefrassoni
  • 111
