I am in my university labs running ubuntu 12.10 with unity and I don't have root privilleges. I need to run a script at logout. Is this possible?
Note: this is probably a duplicate of this question, however the answers given are quite cryptic and no specific directions are given.
geo909
  • 202
This is the step by step procedure of gnome_save_yourself method. Let's do a test.
  1. Save following code as ~/Desktop/execute_script_on_shutdown.sh (From http://www.linuxquestions.org/questions/linux-desktop-74/gnome-run-script-on-logout-724453/#post3560301)
#!/usr/bin/env python
#Author: Seamus Phelan
#This program runs a custom command/script just before gnome shuts #down. This is done the same way that gedit does it (listening for #the 'save-yourself' event). This is different to placing scipts #in /etc/rc#.d/ as the script will be run before gnome exits. #If the custom script/command fails with a non-zero return code, a #popup dialog box will appear offering the chance to cancel logout
#Usage: 1 - change the command in the 'subprocess.call' in
function 'session_save_yourself' below to be what ever
you want to run at logout.
2 - Run this program at every gnome login (add via menu System
-> Preferences -> Session)
import sys import subprocess import datetime
import gnome import gnome.ui import gtk
class Namespace: pass ns = Namespace() ns.dialog = None
def main(): prog = gnome.init ("gnome_save_yourself", "1.0", gnome.libgnome_module_info_get(), sys.argv, []) client = gnome.ui.master_client() #set up call back for when 'logout'/'Shutdown' button pressed client.connect("save-yourself", session_save_yourself) client.connect("shutdown-cancelled", shutdown_cancelled)
def session_save_yourself( *args): #Lets try to unmount all truecrypt volumes
#execute shutdowwn script
retcode = subprocess.call("bash /home/totti/Desktop/shutdown_script.sh", shell=True)
if retcode != 0:
    #command failed
    show_error_dialog()
return True
def shutdown_cancelled( *args): if ns.dialog != None: ns.dialog.destroy() return True
def show_error_dialog(): ns.dialog = gtk.Dialog("There was a problem running your pre-shutdown script", None, gtk.DIALOG_MODAL | gtk.DIALOG_DESTROY_WITH_PARENT, ("There was a problem running your pre-shutdown script - continue logout", gtk.RESPONSE_ACCEPT)) if ns.test_mode == True: response = ns.dialog.run() ns.dialog.destroy() else: #when in shutdown mode gnome will only allow you to open a window using master_client().save_any_dialog() #It also adds the 'Cancel logout' button gnome.ui.master_client().save_any_dialog(ns.dialog)
#Find out if we are in test mode??? if len(sys.argv) >=2 and sys.argv[1] == "test": ns.test_mode = True else: ns.test_mode = False
if ns.test_mode == True: main() session_save_yourself() else: main() gtk.main()
  1. Make it executable:
     chmod +x ~/Desktop/execute_script_on_shutdown.sh
  2. Save the following as ~/Desktop/shutdown_script.sh
     #!/usr/bin/bash
     touch ~/Desktop/AAAAAAAAAAAAAAAAAAAAAAAAAAA
  3. Execute the main script
     bash ~/Desktop/execute_script_on_shutdown.sh
Now you feel the script wait for something
  1. Log Out or shutdown your OS (Ubuntu)
  2. Log in
  3. Check for a file named AAAAAAAAAAAAAAAAAAAAAAAAAAA on your desktop.
     ls -l ~/Desktop/AAAAAAAAAAAAAAAAAAAAAAAAAAA
If you see the file everything OK. Now you can edit the shutdown_script.sh to suit your need. Also remember to execute the execute_script_on_shutdown.sh on login (or make it auto executable on startup).
totti
  • 6,908
  • 40
  • 48
