I have an old machine and the only way I can install Ubuntu is to use Wubi, but i get an error.
Here is the log: http://pastebin.com/a5YjaaKv
01-11 23:09 ERROR  CommonBackend: Invalid md5 for ISO C:\ubuntu\install\installation.iso (5d5d1a7da2a0659b163d4f8bd70fbe6f != 99594c45a0175a5570cdcc5c9cb3ed8f)
None
01-11 23:09 DEBUG  TaskList: ### Finished check_iso
01-11 23:09 DEBUG  TaskList: ## Finished use_cd
01-11 23:09 DEBUG  TaskList: ## Running extract_kernel...
01-11 23:09 ERROR  TaskList: Could not retrieve the required installation files
Traceback (most recent call last):
  File "\lib\wubi\backends\common\tasklist.py", line 197, in __call__
  File "\lib\wubi\backends\common\backend.py", line 618, in extract_kernel
Exception: Could not retrieve the required installation files
Braiam
  • 69,112
samgabbay
  • 704
The CD in the E: drive is bad:
Run wubi.exe without the CD in the computer and it will download a new one, or if you have the ISO you used to create the CD, run wubi.exe in the same directory as the ISO (also making sure the CD is removed).
If that ISO is also bad, then run wubi.exe with no ISO or CD present and it will download a new ISO.
bcbc
  • 6,036
Starting from Ubuntu 13.04, the support for wubi was dropped, as you can see on the page Windows install page:
Windows installer is not compatible with Windows 8 or UEFI firmware, and is not available for Ubuntu 13.04.
bud
  • 78
I've had this issue too mate, now I think it has been fixed already but something else may could've caused it too.
Recently I was trying to install Ubuntu when I found out that a .py source, called "pyrun" actually needs access to your firewall, now.. Ubuntu installation via a CD does not request this, may causing parts to be missing and unable to use in the installation which causes it to fail..
Try to use the CD - Startup Helper Installer, which asks for firewall permission for pyrun. After I did that, the installation completed.
You can also try to delete/eject the mounted image (make sure to have wubi.exe extracted to the desktop) And then run Wubi.
Hope this helps.
