After I figuerd out my ubuntu 12.10 amd64 with 3.5.X Kernel does not fill some queuing, and they've fixed that in kernel 3.8.x, I upgraded the kernel of my Ubuntu to v3.10-saucy with installing deb files from the mainline Kernel archive and things went well.
uname -r
3.10.0-031000-generic
And the
sudo apt-get install linux-image-3.10.0-031000-generic
says me things already installed.
But after I come to compile my C code with gcc, it still claims that the piece of code that suppose to work on > 3.8.x, is undeclared!
The problem is the new installed kernel header is in
/usr/src/linux-headers-3.10.0-031000-generic/include/
but /usr/include still holds the old headers. Gcc still reads from /usr/include for header files.
Then, I came with this:
gcc --verbose -I /usr/src/linux-headers-3.10.0-031000-generic/include/ -o test.out test.c
In file included from /usr/src/linux-headers-3.10.0-031000-generic/include/uapi/linux/if_tun.h:19:0,
from /usr/src/linux-headers-3.10.0-031000-generic/include/linux/if_tun.h:18,
from test.c:3:
/usr/src/linux-headers-3.10.0-031000-generic/include/linux/types.h:14:26: error: conflicting types for ‘fd_set’
In file included from /usr/include/x86_64-linux-gnu/sys/types.h:220:0,
from /usr/include/net/if.h:26,
from test.c:2:
/usr/include/x86_64-linux-gnu/sys/select.h:76:5: note: previous declaration of ‘fd_set’ was here
from test.c:3:
/usr/src/linux-headers-3.10.0-031000-generic/include/linux/types.h:15:25: error: conflicting types for ‘dev_t’
In file included from /usr/include/net/if.h:26:0,
from test.c:2:
/usr/include/x86_64-linux-gnu/sys/types.h:61:17: note: previous declaration of ‘dev_t’ was here
from test.c:3:
/usr/src/linux-headers-3.10.0-031000-generic/include/linux/types.h:19:17: error: conflicting types for ‘nlink_t’
from test.c:2:
/usr/include/x86_64-linux-gnu/sys/types.h:76:19: note: previous declaration of ‘nlink_t’ was here
from test.c:3:
/usr/src/linux-headers-3.10.0-031000-generic/include/linux/types.h:25:26: error: conflicting types for ‘timer_t’
In file included from /usr/include/x86_64-linux-gnu/sys/types.h:133:0,
from test.c:2:
/usr/include/time.h:104:19: note: previous declaration of ‘timer_t’ was here
from test.c:3:
/usr/src/linux-headers-3.10.0-031000-generic/include/linux/types.h:45:26: error: conflicting types for ‘loff_t’
from test.c:2:
/usr/include/x86_64-linux-gnu/sys/types.h:45:18: note: previous declaration of ‘loff_t’ was here
from test.c:3:
/usr/src/linux-headers-3.10.0-031000-generic/include/linux/types.h:112:17: error: conflicting types for ‘u_int64_t’
from test.c:2:
/usr/include/x86_64-linux-gnu/sys/types.h:204:1: note: previous declaration of ‘u_int64_t’ was here
from test.c:3:
/usr/src/linux-headers-3.10.0-031000-generic/include/linux/types.h:113:17: error: conflicting types for ‘int64_t’
from test.c:2:
/usr/include/x86_64-linux-gnu/sys/types.h:198:1: note: previous declaration of ‘int64_t’ was here
from test.c:3:
/usr/src/linux-headers-3.10.0-031000-generic/include/linux/types.h:134:23: error: conflicting types for ‘blkcnt_t’
from test.c:2:
/usr/include/x86_64-linux-gnu/sys/types.h:236:20: note: previous declaration of ‘blkcnt_t’ was here
In file included from /usr/src/linux-headers-3.10.0-031000-generic/include/linux/kernel.h:6:0,
from /usr/src/linux-headers-3.10.0-031000-generic/include/linux/skbuff.h:17,
from /usr/src/linux-headers-3.10.0-031000-generic/include/linux/if_ether.h:23,
from /usr/src/linux-headers-3.10.0-031000-generic/include/uapi/linux/if_tun.h:20,
from test.c:3:
/usr/src/linux-headers-3.10.0-031000-generic/include/linux/linkage.h:7:25: fatal error: asm/linkage.h: No such file or directory
compilation terminated.
Then, I did:
gcc -nostdinc -I /usr/src/linux-headers-3.10.0-031000-generic/include/
to don't let gcc to access /usr/include. But it claims again some include files like <net/if.h> not found and by removing that header files, it gives some other not found crap inside the found include files either.
If <net/if.h> is related to c library, it could be right, because make the gcc not to read other include folders.
But it reports some not found inside
<linux/if_tun.h>
In file included from /usr/src/linux-headers-3.10.0-031000-generic/include/linux/types.h:5:0,
from /usr/src/linux-headers-3.10.0-031000-generic/include/uapi/linux/if_tun.h:19,
from penvpn-multithread-udp.c:3:
So how do I suppose to get over this?
