I would like to temporarily (until next boot) disable a kernel module.
How can I do this?
Use lsmod to find the name of a kernel module about that you are interested in temporarily disabling. After you've found the name, use this command to disable the module:
sudo modprobe -r <module_name>
However, this command will fail with an error message something like FATAL: Module <module_name> is in use if a process is using:
<module_name><module_name> directly depends on<module_name> - through the dependency tree - depends on indirectly.You can use lsmod | grep <module_name> to obtain the names of the modules which are preventing you from temporarily disabling a certain module (these module names are listed in the last column).
More about:
It appears:
sudo modprobe -r moduleName
Achieves what I want. The module is removed and reloaded upon reboot.
