I'm trying to download something, and it's stuck on "waiting for apt-get to exit". Also, when I'm trying to use the terminal it says "unable to lock the administration directory" after I type in a command.
Asked
Active
Viewed 4.3k times
apt-get is a tool for handling dpkg packages and handles one package at a time. There's may be a case that your previous action is still engaging the apt-get engine. Just like @karel suggested, 'close first and then only try another'
apt-get thread was halted while executing, leaving apt locked.
You'll need to delete the lock file with sudo rm /var/lib/apt/lists/lock and also the lock file in cache directory with sudo rm /var/cache/apt/archives/lock
kern
- 1,489
Maybe you had two conflicting package download commands trying to run at the same time, so neither command would run. If so, try closing all your open windows, and then open only the Ubuntu Software Center and try again to install your package.
karel
- 122,292
- 133
- 301
- 332
