When I tried to mount my hard drive following error got displayed. I am very new to linux. Please help.
mount /dev/sda2 /media/shashi/ -t ntfs -o nls=utf8,umask=0222
mount: only root can do that
what should I do to give root level access?
Eric Carvalho
  • 55,453
Shashi
  • 41
Use sudo:
sudo mount /dev/sda2 /media/shashi/ -t ntfs -o nls=utf8,umask=0222
Eric Carvalho
  • 55,453
You will have to mount the partition as root unless you add an entry to /etc/fstab
If you want to mount the partition as a user, without root access,
Open /etc/fstab as root. In a terminal, run
sudo nano /etc/fstab
At the bottom of the file add
/dev/sda2 /media/shashi/ ntfs users,noauto,nls=utf8,umask=0222 0 0
Change "noauto" to auto if you want it to automatically mount when you boot.
Then, make the mount point if it does not exist
sudo mkdir /media/shashi
Then you can mount as a user.
mount /media/shashi
For details see
https://help.ubuntu.com/community/Fstab
https://help.ubuntu.com/community/AutomaticallyMountPartitions
Panther
  • 104,528
