My Ubuntu has been running pretty slow, but I don't know why. I have the latest updates and all. I installed Ubuntu i368 on a AMD processor does that effect the speed? Thank you.
Very little information to go on here, but I'm going to take a shot at it anyway. Normally when Ubuntu gets laggy for no obvious reason it has to do with gvfs-metadata. This is particularly true if you've been moving files around a bit. It's a pretty easy fix. All you have to do is close Nautilus or whatever file browser you are running, open an terminal and type the following:
pkill gvfsd-metadata
then hit ENTER and when you get the prompt back, type:
rm -rf ~/.local/share/gvfs-metadata
The first command stops the gvfsd process, and the second command erases gvfs-metadata file which often becomes corrupt or just too big. Don't worry, though, a fresh new gvfs-metadata file is created as soon as the gvfsd process starts back up. At the very least this does no harm and gives you a bit more speed / CPU usage. The worst case scenario is that you see a bit of improvement. The best case is that this fixes your problem.
- 247
If you followed Blind Fish replied you may also would want to consider installing Preload, (adaptive readahead daemon) see here:https://apps.ubuntu.com/cat/search/?q=preload&op= read the description FYI....
Luis
- 80
