When I (try to) run uget in Ubuntu 13.04 I get this error:
user-pc:~$ uget-gtk
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 9: reading configurations from ~/.fonts.conf is deprecated.
Segmentation fault (core dumped)
How can I solve this problem?
If you still have Segmentation fault (core dumped) message when trying to start uGet, a quick fix is
backup and delete uGet folder in .config/uGet. Then restart uGet
and it will be working again. Most likely issue is with DownloadList.xml (for some reason a error there dump uget core). However by doing so You will lose all your categories, settings and list of downloaded files.
danijelc
  • 898
The problem is you are using the Ubuntu repository...and for some reason Canonical refuses to update the app there.
Ubuntu Software Center has version 1.8.2 which is not even compatible with Ubuntu 12.04 or newer.
The latest version of uGet is 1.10.3 and is available from http://uGetdm.com/downloads
A PPA is also available from that page.
delete home/user/.config/uget/ folder and reinstall aria2 solves the problem to me running kubuntu 18.04 bionic beaver
I had segmentation fault error for version 2.0.8 and the problem was changing the download mode to aria2+curl in the setting but not having aria2 installed!
After installing aria2 it's working again.
sudo apt install aria2
sajjadG
  • 647
