I am having problem with my memory device (actually a memory card that act external memory device like pendrive).
experimentx@workmateX:/var/www/zendtest$ sudo rm /media/A88F-8788/python-2.7.1-docs-html.zip
rm: cannot remove `/media/A88F-8788/python-2.7.1-docs-html.zip': Read-only file system
I tried to change the file permission of the system but that doesn't work
experimentx@workmateX:/var/www/zendtest$ sudo chmod 0777 /media/A88F-8788/python-2.7.1-docs-html.zip
chmod: changing permissions of `/media/A88F-8788/python-2.7.1-docs-html.zip': Read-only file system
But it perfectly works on windows.
UPDATE
On opening the drive and running command sudo mount -o remount,rw /media/A88F-8788
/var/log/syslog:
Mar 23 15:29:48 workmateX kernel: [18042.257407] fat_get_cluster: 11 callbacks suppressed
Mar 23 15:29:48 workmateX kernel: [18042.257414] FAT: Filesystem error (dev sdb1)
Mar 23 15:29:48 workmateX kernel: [18042.257418] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:29:48 workmateX kernel: [18042.257425] FAT: Filesystem has been set read-only
Mar 23 15:29:48 workmateX kernel: [18042.258187] FAT: Filesystem error (dev sdb1)
Mar 23 15:29:48 workmateX kernel: [18042.258194] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.333787] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.333795] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.335949] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.335957] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.354903] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.354911] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.357213] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.357221] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.359547] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.359555] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.361929] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.361936] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.377416] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.377424] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.379384] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.379392] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.381898] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.381906] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:35 workmateX kernel: [18149.383764] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:35 workmateX kernel: [18149.383772] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.569747] fat_get_cluster: 11 callbacks suppressed
Mar 23 15:31:40 workmateX kernel: [18154.569754] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.569758] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.569765] FAT: Filesystem has been set read-only
Mar 23 15:31:40 workmateX kernel: [18154.572022] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.572029] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.582933] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.582941] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.585921] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.585929] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.587819] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.587827] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.597547] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.597555] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.599503] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.599511] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.602896] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.602905] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.615338] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.615346] fat_get_cluster: invalid cluster chain (i_pos 0)
Mar 23 15:31:40 workmateX kernel: [18154.618574] FAT: Filesystem error (dev sdb1)
Mar 23 15:31:40 workmateX kernel: [18154.618581] fat_get_cluster: invalid cluster chain (i_pos 0)
var/log/message:
Mar 23 15:29:48 workmateX kernel: [18042.257407] fat_get_cluster: 11 callbacks suppressed Mar 23 15:31:40 workmateX kernel: [18154.569747] fat_get_cluster: 11 callbacks suppressed
