I want to clear space on my computer in order to download drivers for my internet, so I tried moving files to a different location.
Unfortunately I don't have permission to do this. How do I change this? I should point out that I am not logged in; I think I'm a guest or something because if I log in I cannot gain access to the internet to download the drivers that I need, so I'm using the live cd in Try Ubuntu mode to try achieve downloading the drivers.
Zanna
  • 72,312
James
  • 19
To move files, you can use (1) sudo to execute a command as the root and ()2) mv to move them. You must open a Terminal, for instance, by pressing Ctrl+Alt+T on your keyboard to open Terminal and run the follwing command:
$ sudo mv -f -i <Source> <Destination>
The -f option will force the move. The -i will instruct mv to ask for permission before overwrite some file. Example: sudo mv -f -i /home/user/test /home/user/test1
To copy the files, you can use
sudo cp -i -v <Source> <Destination>
Example: sudo cp -i -v /home/user/test /home/user/test1
Jaime
  • 1,440
-1
If you use the Try Ubuntu feature and fire up Terminal, type in the following command:
    sudo su
This will log you in as super user without typing a password. You should see the word root before the prompt. Then you can change directory and you will have permission.
