I'm trying to apt-get -f install on my Ubuntu 12.04 server. I get the following error message:
After this operation, 157 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 122731 files and directories currently installed.)
Unpacking linux-image-3.5.0-34-generic (from .../linux-image-3.5.0-34-generic_3.5.0-34.55~precise1_amd64.deb) ...
Done.
dpkg: error processing /var/cache/apt/archives/linux-image-3.5.0-34-generic_3.5.0-34.55~precise1_amd64.deb (--unpack):
 failed in write on buffer copy for backend dpkg-deb during `./boot/vmlinuz-3.5.0-34-generic': No space left on device
No apport report written because the error message indicates a disk full error
        dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.5.0-34-generic /boot/vmlinuz-3.5.0-34-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.5.0-34-generic /boot/vmlinuz-3.5.0-34-generic
My primary disk isn't full - however, my boot partition is only ~100MB. Is apt-get trying to install stuff to /boot? It does mention trying to do something to ./boot/vmlinux[...]
I get a longer but eventually similar error trying to apt-get -f upgrade as well. What's going on?
uname -r yields simply 3.5.0-31-generic dpkg -l | grep linux-imageyields this:
ii  linux-image-3.5.0-28-generic      3.5.0-28.48~precise1         Linux kernel image for version 3.5.0 on 64 bit x86 SMP
ii  linux-image-3.5.0-30-generic      3.5.0-30.51~precise1         Linux kernel image for version 3.5.0 on 64 bit x86 SMP
ii  linux-image-3.5.0-31-generic      3.5.0-31.52~precise1         Linux kernel image for version 3.5.0 on 64 bit x86 SMP
iU  linux-image-generic-lts-quantal   3.5.0.32.39                  Generic Linux kernel image
Which I'm guessing means I have a certain number of kernels that I could purge? But when I try to apt-get purge, it asks me to run apt-get -f install because of an unmet dependency...
And yeah, I checked disk space and /dev/sda (which is /boot/) is 100% full. This install has been running ~40 days total, and has been booted once (today)I I did some research before deciding on a /boot size, and 100MB seemed to be a pretty reasonable size. What's going on?
I tried running apt-get clean, autoclean, autoremove, and manually purging a given kernel. I keep getting
 linux-image-generic-lts-quantal : Depends: linux-image-3.5.0-32-generic but it is not installed
E: Unmet dependencies. Try using -f.
effovex
