I'm using a Dell with Windows and I am also using Ubuntu as a 2nd OS by wubi. When I boot into ubuntu I have two Hard drive icons one labeled DELLUTILITY and the other labled as recovery on my desktop. These really annoy me. I can unmount them but I'm worried that this will cuase a problem to my computer or even mess up windows when I boot into it.
What can I do or should I do?
Bruno Pereira
  • 74,715
Lolk
  • 137
You should be able to unmount the DELLUTILITY partition at anytime. Mamually, enter the command:
sudo umount <mount point>
If you want to avoid having the partition always mounting, first get the actual partition name that contains the Dell Utility. To do this, enter the command:
mount
and see which one it is, for example, /dev/sda1 or a long series of digits.
as root (sudo), edit the file /etc/fstab and remove (or comment out) the line that mounts that partition.
This will disablemounting this partition in the future, but will not prevent you from manually mounting it manually.
8128
  • 28,868
jfmessier
  • 6,366
