I did not provide swap space while installing Ubuntu. How shall i give the swap space now? I've a multibooted system with win xp and ubuntu. please help
This will create a swap file of 512MB, using space from /dev/sda5 since you're only using up about 8% of it.
Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo dd if=/dev/zero of=/swapfile bs=1024 count=512k sudo mkswap /swapfile
Finish up by activating the swap file:
sudo swapon /swapfile
To make the swap permanent add it to the fstab file.
sudo gedit /etc/fstab
Paste in the following line:
 /swapfile       none    swap    sw      0       0
And finally set up the correct permissions on the swap file:
sudo chown root:root /swapfile
sudo chmod 0600 /swapfile
Source:DigitalOcean
Mitch
  • 109,787
First you must to free up some space and make a swap partition using a program like GParted.
After you made a new swap partition, follow this answer: https://askubuntu.com/a/33700/147044.
To calculate the size of swap partition, use this answer: https://askubuntu.com/a/49138/147044.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
