I have XP Pro on C drive and there is plenty of room left on said drive. I read to use "Windows installer for Ubuntu Desktop". It seems to create to partition but does it also install Ubuntu at the same time? I can put Ubuntu 12.04 64 bit onto my USB drive. Is making the partition with Windows installer a two part operation? First make the partition then go and do the install of Linux.
Asked
Active
Viewed 50 times
The Windows installer does not create a partition. It instead installs Ubuntu as a program. This installer only works on Windows 7, so do not try it on XP.
To dual-boot the easy way:
- Download the Desktop Installer (it should be an ISO file) and burn it to a CD.
- Boot your computer into the CD (you may have to modify the boot order in your BIOS)
- Choose Install Ubuntu.
- When asked how you want to install Ubuntu, choose Install Ubuntu alongside Windows XP.
Follow the installation procedure and you should be fine. You do not need to create any partitions because Ubuntu does that for you. If your computer boots into Windows instead of GRUB, reboot into the CD, choose Try Ubuntu Before Installing, and open a Terminal (Ctrl+Alt+T). Then, run sudo apt-get install boot-repair followed by gksudo boot-repair. Reboot again and Ubuntu should work fine.
