I have a package installed (xcp-xapi) which is prone to a bug. The fix is very simple (only a couple of lines in the code) so what I do is the following:
apt-get source xcp-xapi
Then I find the source file to apply the fix and then I run again
apt-get -b source xcp-xapi
This will produce some .deb files that I install using
dpkg -i *.deb
Now the problem is that every time I try to run an apt-get upgrade, apt tries to fetch the packages from the repositories. I guess this can be fixed using pinning, but I cannot find the proper configuration to put in high priority the packages I compiled on my own.
So the question is how can I configure pinning to put the following already installed packages on higher priority than any existing in the repositories?
# apt-cache policy xcp-networkd xcp-v6d xcp-xapi xcp-xapi-debug
xcp-networkd:
  Installed: 1.3.2-5ubuntu0.1
  Candidate: 1.3.2-5ubuntu0.1
  Version table:
     1.3.2-5ubuntu0.1 0
        500 http://ftp.uninett.no/ubuntu/ precise-updates/universe amd64 Packages
        500 http://security.ubuntu.com/ubuntu/ precise-security/universe amd64 Packages
 *** 1.3.2-5ubuntu0.1 0
        100 /var/lib/dpkg/status
     1.3.2-5 0
        500 http://ftp.uninett.no/ubuntu/ precise/universe amd64 Packages
xcp-v6d:
  Version table:
     1.3.2-5ubuntu0.1 0
     1.3.2-5 0
xcp-xapi:
  Version table:
     1.3.2-5ubuntu0.1 0
     1.3.2-5 0
xcp-xapi-debug:
  Version table:
     1.3.2-5ubuntu0.1 0
     1.3.2-5 0
I don't know if this is the proper solution, but trying different pinning configurations, I end up made it working like this:
create the file /etc/apt/preferences.d/xcp-xapi with the following contents:
Package: xcp-networkd
Pin: release n=precise
Pin-Priority: -1
Package: xcp-v6d
Pin-Priority: -1
Package: xcp-xapi
Pin-Priority: -1
Package: xcp-xapi-debug
Pin-Priority: -1
From what I understand, giving it a negative priority to the specific package from the specific repository means do not bother for this package, thus keep the current version installed. If someone can explain further or provide a "more correct" solution, I would appreciate it. Thank you!
One way might also be to send a bug report and patch to the developers of the xcp-xapi, and over time the bug might be fixed in the repositories. Then you can install the version from the repository again. That said, it might take some patience before the repositories are updated.
