I tried to install Ubuntu with an usb stick. I used unetbootin. Everytime I tried it, there was an error:
"invalid or corrupt kernel"
I tried with several sticks. What could be the problem?
Greetings from Germany Michael
If you used that stick to deploy other distrib, try to clean older install files on the USB stick before applying the ISO ( I personally got problem with old files of previous installation made by Unetbootin).
Emmanuel
  • 1,333
-1
To install from a USB stick, just:
  1. Download Rufus
  2. Run Rufus and select your USB stick as the device
  3. Click Start
  4. Once Rufus is done, reboot to BIOS on the computer you wish to install on
  5. Change the boot order to USB first
  6. Plug in your USB if it is not still plugged in and cold reboot your computer
  7. The computer should boot straight to Ubuntu, from which you can install as if from a disk
I have tried this process and it worked for me. Also, be sure to make sure your checksums match for your iso.
Dillmo
  • 2,000
