I have dell inspiron q17r with two graphic cards and I noticed that it is overheating. I installed bumblebee, jupiter and flashblock, I followed this but it still got to even 74C. Here I found something:
Power management relies on ACPI, disabling ACPI renders bbswitch unusable. Be sure that your kernel boot parameters do not contain on of the options noacpi, pci=noacpi, acpi=off.
And I changed it to pci=noacpi because without it didn't even started.. I followed this but in point 4. I installed bumblebee instead.
What should I do?
Wilf
  • 30,732
mati
Have you considered getting a cooling pad for your laptop? My brother's laptop has the same problem, but a cooling pad does a good job of preventing overheating.
Dillmo
  • 2,000
Try changing pci=noacpi to pci=acpi- basically it should enable ACPI. (src: from edit on your post:)
EDIT: So I changed pci=noacpi to pci=acpi and.. it's working great :) don't know what are the consequences but the temperature is lower than on windows :)
I think this was simply a case you misread this :)
Wilf
  • 30,732
