59
I have an extra IP address available to my server, and so I need to assign it in the interfaces file. At the moment, I've got this:
auto lo
iface lo inet loopback
  auto eth0
iface eth0 inet static address aaa.aaa.aaa.aaa netmask 255.255.254.0 gateway bbb.bbb.bbb.bbb dns-nameservers ccc.ccc.ccc.ccc ddd.ddd.ddd.ddd eee.eee.eee.eee dns-search vps-number.com
What do I add/assign my new IP address (fff.fff.fff.fff)? And how do I then restart it to accept the new configuration?
Alexis Wilke
  • 2,787
auto lo
auto eth0
auto eth0:0
iface eth0:0 inet static
  address fff.fff.fff.fff
Then you can run sudo ifup eth0:0 to bring it up and sudo ifdown eth0:0 to bring it down.
Eric Carvalho
  • 55,453
41
You can just have repeated iface stanzas for the same interface. Example from https://wiki.debian.org/NetworkConfiguration#Multiple_IP_addresses_on_one_ :
auto eth0
allow-hotplug eth0
    address 192.168.1.42/24
    gateway 192.168.1.1
    address 192.168.1.43/24
    address 192.168.1.44/24
# adding IP addresses from different subnets is also possible
    address 10.10.10.14/24
So just the solution above but drop the :x suffix, which as Heihachi points out is outdated.
(The ip addr suggestion is the worst. It's ugly and incomplete, as you'll have to also add a down variant or ifdown won't work very cleanly.)
Wilmer
  • 528
27
For an extra IP address, I usually add:
up ip addr add fff.fff.fff.fff/prefixlen dev $IFACE
to the bottom of the iface eth0 inet static stanza for future reboots and then run the command sudo ip addr add fff.fff.fff.fff/prefixlen dev eth0 again manually to activate it directly.
If your netmask is 255.255.254.0 then prefixlen should be 23 for you.
I'd love to know if there's a better way, though.
0xC0000022L
  • 5,870
Robie Basak
  • 15,910
