I have an old receiver (USB) and remove control that i am trying to get working on Ubuntu with Boxee.
Any suggestions for setting this up? software I need.
Jorge Castro
  • 73,717
myusuf3
  • 35,659
Install gnome-lirc-properties "Infrared Remote Control" from Ubuntu Software Center or
sudo apt-get install gnome-lirc-properties
It will set up the configuration for your remote in lirc and allow you to test the remote.
After setting that up you need to set up your remote with boxee file. Next Boxee needs a config file for the remote. Copy /opt/boxee/system/Lircmap.xml to $HOME/.boxee/Lircmap.xml.
Now open the Lircmap.xml copy that is in the UserData folder, and add the code from this forum post just before the ending tag:
<remote device="Streamzap_PC_Remote">
    <pause>PAUSE</pause>
    <stop>STOP</stop>
    <forward>&gt;&gt;</forward>
    <reverse>&lt;&lt;</reverse>
    <left>LEFT</left>
    <right>RIGHT</right>
    <up>UP</up>
    <down>DOWN</down>
    <select>OK</select>
    <pageplus>CH_UP</pageplus>
    <pageminus>CH_DOWN</pageminus>
    <back>EXIT</back>
    <menu>MENU</menu>
    <title>PLAY</title>
    <info>More</info>
    <skipplus>&gt;&gt;|</skipplus>
    <skipminus>|&lt;&lt;</skipminus>
    <display>Teletext</display>
    <start>Home</start>
    <record>RECORD</record>
    <volumeplus>VOL_UP</volumeplus>
    <volumeminus>VOL_DOWN</volumeminus>
    <mute>MUTE</mute>
    <power>POWER</power>
    <myvideo>Videos</myvideo>
    <mymusic>Music</mymusic>
    <mypictures>Pictures</mypictures>
    <mytv>TV</mytv>
    <one>1</one>
    <two>2</two>
    <three>3</three>
    <four>4</four>
    <five>5</five>
    <six>6</six>
    <seven>7</seven>
    <eight>8</eight>
    <nine>9</nine>
    <zero>0</zero>
    <mytv>RED</mytv>
    <mymusic>GREEN</mymusic>
    <mypictures>YELLOW</mypictures>
    <myvideo>BLUE</myvideo>
</remote>
Edit the keys for your particular remote.
Save the file and open Boxee, and the remote should now work.
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
Li Lo
  • 16,382
