37
I have these three files: 1.zip, 1.z01 and 1.z02. I would like to extract and join them into a single file, by right clicking 1.zip and selecting Extract Here. But then there comes an error:
7-Zip 9.04 beta  Copyright (c) 1999-2009 Igor Pavlov  2009-05-30
p7zip Version 9.04 (locale=en_US.utf8,Utf16=on,HugeFiles=on,2 CPUs)
Error: /home/tim/Desktop/1.zip: Can not open file as archive
Errors: 1
I was wondering what the problem is and how I can solve it?
ADDED:
Is my usage of unzip -FF wrong? It seems not working:
$ unzip -FF 1.zip
Archive:  1.zip
warning [1.zip]:  zipfile claims to be last disk of a multi-part archive;
  attempting to process anyway, assuming all parts have been concatenated
  together in order.  Expect "errors" and warnings...true multi-part support
  doesn't exist yet (coming soon).
file #1:  bad zipfile offset (local header sig):  0
2nd ADDED:
Still ain't right:
$ cat 1.z01 1.z02 1.zip > combined.zip && unzip -FF combined.zip
Archive:  combined.zip
warning [combined.zip]:  zipfile claims to be last disk of a multi-part archive;
warning [combined.zip]:  209829313 extra bytes at beginning or within zipfile
  (attempting to process anyway)
file #1:  bad zipfile offset (local header sig):  209829313
  (attempting to re-compensate)
 extracting: 1.wmv   bad CRC ee181eef  (should be f3c61875)
It generated 1.wmv, which can play well only until midway in GNOME MPlayer.
3rd ADDED:
Am I using 7z wrongly?
$ 7z e 1.z01
7-Zip 9.04 beta Copyright (c) 1999-2009 Igor Pavlov 2009-05-30 p7zip Version 9.04 (locale=en_US.utf8,Utf16=on,HugeFiles=on,2 CPUs)
Processing archive: 1.z01
Error: Can not open file as archive
$ 7z e 1.zip
Processing archive: 1.zip
Tim
  • 26,107
9 Answers9
40
Try:
zip -FF 1.zip --out 1-full.zip
unzip -FF 1-full.zip
I think most likely some data is broken many times so you need the -FF still in unzip. A single -F may work also though.
MiJyn
  • 3,396
TNT
  • 401
23
Put all your zip files in the same directory: zip_file.z01, zip_file.z02, zip_file.z03, ..., zip_file.zip
In Zip 3.0 version the following commands worked for me:
$ zip -s- zip_file.zip -O zip_file_full.zip
$ unzip zip_file_full.zip
As noted in the comments, using a - sign after the command line option -s joins all the zip files together and writes it as a single zip file which you can then extract using the unzip command.
kmario23
  • 1,039
15
I have the same issue today with Mass Effect 3. Someone broke the installation of Mass Effect 3 in new version of origin on windows and my wine of course too (installation hangs on 99%). I have to make manually installation:
cp /mnt/cdrom1/Mass\ Effect\ 3.z01 ~/temp/Mass\ Effect\ 3.z01
cp /mnt/cdrom2/Mass\ Effect\ 3.zip ~/temp/Mass\ Effect\ 3.zip
zip -FF Mass\ Effect\ 3.zip --out Mass\ Effect\ 3.zip.fixed
mkdir Mass\ Effect\ 3
unzip -d Mass\ Effect\ 3/ Mass\ Effect\ 3.zip.fixed
du --total Mass\ Effect\ 3
>> 10466048 (~10.5 GB => success)
zip -FF should be applied to last part of archive, it will automatically check for all parts
puchu
  • 326
I also had some issues. man unzip said the following:
Also, zip 3.0 and later can combine multi-part (split) archives into a combined single-file archive using ``zip -s- inarchive -O outarchive''.
This (zip -s- vmdkdisk -O combined) seems to work for me... (combine vmdkdisk.z01 and vmdkdisk.zip into one file combined.zip)
Sebas
  • 41
According to reading man zip, "Split .zip" archives can be recombined and unpacked using unzip -FF.
sladen
  • 6,534
Above solution by kmario23 is correct I see some typo errors. Here is another example.
    pramodimac:SDK pramod$ pwd
    /Users/pramod/Downloads/SDK
    pramodimac:SDK pramod$ ls -ltrh
    total 150104
    -rw-r--r--@ 1 pramod  staff   1.3M Jun  3 11:56 SDK.zip
    -rw-r--r--@ 1 pramod  staff    18M Jun  3 11:58 SDK.z03
    -rw-r--r--@ 1 pramod  staff    18M Jun  3 11:58 SDK.z04
    -rw-r--r--@ 1 pramod  staff    18M Jun  3 11:58 SDK.z01
    -rw-r--r--@ 1 pramod  staff    18M Jun  3 11:58 SDK.z02
    pramodimac:SDK pramod$ zip -s 0 SDK.zip --out single.zip
    total 300208
    -rw-r--r--  1 pramod  staff    73M Jun  6 22:26 single.zip
    pramodimac:SDK pramod$ unzip single.zip
Go to the directory where the archives are, through terminal.
If they are on desktop, command is:
cd ~/Desktop
~ is your home folder name. Create full archive, by using this command:
zip -F (name of last part of archive, which will end with .zip, not .z0X) --out (desired output name of compiled archive, if has spaces put " marks around the name).zip
Full archive is now created.
Unpack the full archive, by using this command:
unzip (full archive name, with " marks around it if has spaces).zip -d (destination folder directory, see first step)
v2r
  • 9,707
86434
It appears 7zip doesn't support multi-volume ZIP archives.
Igor Pavlov states it in this forum thread
saji89
  • 12,187
Keep in mind that if your follow up files (01, 02 etc.. ) are created by Windows (Z01, Z02 etc..) your linux will not find them. You need to rename the files to z01, z02 ..
