I know that in bash you can set up aliases in a .bash_aliases file, so that the command you type doesn't need to be a command stored in the binaries in the system. Is there any way I can get aliases into zsh?
- 16,703
- 78,878
I go back and forth between bash and zsh, and use the same .aliases file for both. They share the same basic alias syntax, so you can create a .aliases file and link it to .bashrc and .zshrc:
.bashrc
if [ -f ~/.aliases ]; then
. ~/.aliases
fi
.zshrc
source $HOME/.aliases
FWIW this can also be done with environment variable declarations, in a separate .env file.
You can do it by the "alias" command with this syntax:
alias [ -gmrL ] [ name[=value] ... ]
For "gmrL" switches, see this guide, which is my reference.
For each name, with no value, zsh will print the name and what it is aliased to previously. With no arguments at all, alias prints the values of ALL defined aliases.
To define one or more aliases, simply enter:
alias name1=value1 name2=value2 ... nameX=valueX
For each name with a corresponding value, zsh defines an alias with that value. For further info, check out that link. ;-)
You generally put them in ~/.zshenv. But many programs use /bin/sh (usually bash) instead of $SHELL to execute shell commands, so for it to work everywhere you will probably need to put the bash equivalent of the alias into ~/.bash_aliases anyway.
- 11,777
I was trying some things and I found a way to use my aliases created in bash into zsh, only I had to copy these lines from bashrc:
if [ -e ~/.bash_aliases ]; then
. ~/.bash_aliases
fi
- 387
- 41
What I've found from official guide for Zsh it could be done by code below in your .zshrc:
if [[ -r ~/.aliasrc ]]; then . ~/.aliasrc fiwhich checks if there is a readable file
~/.aliasrc, and if there is, it runs it in exactly the same way the normal startup files are run. You can usesourceinstead of.if it means more to you;.is the traditional Bourne and Korn shell name, however.
- 16,703
- 21
If anyone find this useful: My situation is that I have a Macbook Laptop, Ubuntu Laptop, Ubuntu Desktop and couple of Ubuntu VMs. In all of them I want to use defaults (so Bash in Ubuntu and Zsh in OSX) but with same aliases.
The way I handle it is that I have my alias file .bash_aliases in git repo called dotfiles. I just clone the repo in all my computers and I just create a symlink to the alias file:
ln -s "~/wherever_i_store_git_repos/dotfiles/.bash_aliases" "~/.bash_aliases"
in Ubuntu I add this to ~/.bashrc :
if [ -f ~/.bash_aliases ]; then
. ~/.bash_aliases
fi
in OSX I add this to .zshrc :
source $HOME/.bash_aliases
fi
note: Alternatively if you don't use git you can ln -s a Dropbox folder
- 561
- 2
- 5
- 12
