I have an Acer Aspire One. Not sure what version. I've had it for a year or two on Windows and then suddenly, I couldn't boot Windows anymore. So I decided to use Ubuntu. I first tried Ubuntu 13.04. It said my hard disk was faulty. So, I decided to try a lower version: 12.04. Whenever I get to the part where it starts creating ext4 file system, it gets stuck. I know that it is stuck because I have waited for 1-2 hours, and it didn't move a bit.
I don't know what I am doing wrong. Maybe my hard drive is ruined or something. I don't know. Any Ubuntu installer I try never works to go through the whole installation. I have been using a liveCD for my installation.
I have tried the Disk Utility. It says that a few sectors are bad. Only two when I checked. Those sectors didn't seem very important. For the memory test, There was only one failing address. It also said my Err-Bits were 80000 and the Count Chan 1.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Check your hardware.
It says my hard disk has a few bad sectors. The Reallocated Sectro Count and the Current Pending Sector Count. Not sure whether that affects my hard drive. I tried the installation again and while copying files, it had an error saying that the hard drive might be faulty and stuff.
Replace the hard drive. It has already failed or it will fail soon. This is very likely to be the cause.
This also does not sound very good. Memory should not fail, or else you will be suffering from data corruption.
gertvdijk
  • 69,427
Boot from the 12.04 Live CD/DVD/USB select try Ubuntu without installing click on the Ubuntu symbol at the top left of your screen, write disks in the search field, there should only one programm appear start it.
On the left are your devices listed click on your harddrive, on the right schould now appear SMART-Status: (something) if this says your disk is bad then you should buy a new harddisk.
user58634
  • 868
