how to install gimp webp plugin? I found out that we can do it using with gimp-plugin-registry, but donno how. I have install gimp-plugin-registry extension for gimp from ubuntu software center, now what should i do?
I also found out that we can put plugins in /usr/lib/gimp/2.0/plug-ins/, so i tried to compile the gimp webp plugin src. I installed libwebp-dev and ran make in plugin source folder. It says
Package gtk+-2.0 was not found in the pkg-config search path.
so i decided to install libgtk package but i found both libgtk2.0-dev and libgtk-3-dev. Is libgtk-3-dev is latest release of the libgtk2.0-dev? If so is it ok if I installed the later one?
I want to know at least how to install the plugin with gimp-plugin-registry and i will be more happy if i can do it by compiling src.
----------EDIT----------
I've installed libgtk-3-dev and ran make and it threw same error, I carried on with libgtk2.0-dev, Now it throws Package gimp-2.0 was not found in the pkg-config search path. There is no gimp-dev in repositories! I got stuck!
Nathan Osman
  • 32,495
Necktwi
  • 1,087
Note: the WebP plugin is going to be included in the next version of the Gimp (version 2.8+) as a built-in plugin (later, this plugin was shipped in GIMP 2.9 branch, and received multiple improvements). The PPA can still be used to enable WebP support in the meantime.
I have updated the packages available in the WebP PPA to the latest Ubuntu releases. After adding the PPA, you can use the plugin simply by installing the gimp-webp package.
I also migrated the plugin over to CMake, so building the plugin is a lot easier now:
  1. Install the following packages:
     sudo apt-get install build-essential git cmake libgimp2.0-dev libwebp-dev
  2. Checkout the source code:
     git clone https://github.com/nathan-osman/gimp-webp
  3. cd to the new directory and create a build/ directory:
     cd gimp-webp
     mkdir build
     cd build
  4. Build the plugin:
     cmake ..
     make
  5. Install the plugin:
     sudo make install
That's it!
Pablo Bianchi
  • 17,371
Nathan Osman
  • 32,495
