LAPTOP: HP Envy 6-1002TX Ubuntu version: 13.04 & 11.04
While installation computer doesn't restart and is stuck on a purple screen.
i had used the same pen drive for installing Ubuntu on an other dell laptop and it worked fine, so i think nothing is wrong with the pen drive.
My first two partitions are for windows and i have three logical drives as '/boot', '/' and 'swap'. I have the USB drive checked for errors. Legacy mode is enable & secure boot disabled.
And if i forcefully shut down the PC after installation and boot it back it loads windows, and there is no menu to select Ubuntu(assuming Ubuntu installed properly, which i doubt) I then used EasyBCD to add an entry for Ubuntu but when i boot into Ubuntu using this forced entry a black screen appears with the following written on it: GRUB4DOS 0.4.5c ...... Minimal Bash-like editing is supported.... and a cursor blinking
So is Ubuntu installed or not? if yes, why is it not working? and if it is not installed properly, what should i do now?
UPDATES: I even tried to install the graphic drivers while in the live USB mode and install Ubuntu. But it won't install.
Tim
  • 33,500
Madhur
