I've followed the directions here on the Ubuntu help wiki for my 12.04.2 Ubuntu Server running in VMware Fusion 5, and everything looks good, so I do a echo c > /proc/sysrq-trigger as root. It panics the kernel as expected, and then hangs after printing out a bunch of stack traces.
I waited a few minutes to make sure any writes to disk (for the crash dump) finished, and I restarted the VM. When I log in again, ls /var/crash shows no files! Any idea how to get it to work, or whether it works at all?
Zanna
  • 72,312
Dan
  • 360
The reason why this doesn't work properly has been well documented for over three or so years now: see this page of the Ubuntu wiki
On systems with <= 2G RAM we won't reserve enough memory for the crash kernel's initrd to fit. That will cause the crash-kernel to panic.
See also these bug reports for reference #785394 and #1235616
Workaround:
To fix this issue set
GRUB_CMDLINE_LINUX="crashkernel=128M"
in /etc/default/grub. n.b.: You cannot put this option into GRUB_CMDLINE_DEFAULT, because the the setting in /etc/grub.d/10_linux takes precedence over that.
To "permanently" fix the issue, edit `/etc/grub.d/10_linux and change the line
GRUB_CMDLINE_EXTRA="$GRUB_CMDLINE_EXTRA crashkernel=384M-2G:64M,2G-:128M"
to
GRUB_CMDLINE_EXTRA="$GRUB_CMDLINE_EXTRA crashkernel=128M"
Zanna
  • 72,312
The problem might be your RAM is too low. It should be greater than 2GB otherwise you have to change GRUB parameters to accept crashkernel=128M and check
cat /sys/kernel/kexec_crash_loaded
It should be 1.
Zanna
  • 72,312
