I have successfully installed Ubuntu 13 on my laptop using an 4Gb USB drive with a bootable .ISO However I went to try and format the USB on my desktop(Windows 7 :( ) and now it only has 700Mb Is there any way to get my 4Gbs back, or have I lost it forever?
EDIT: 21/06/13 Thanks guys, got my USB back
A.B.
  • 92,125
Can you explain a little bit more your problem? The only thing I have in mind is that when you formatted your USB, you problably changed its size to 700mb... Try reformatting it and using the default format option in Windows, and check the options on the window...
(Psss... I can't show it with images, I'm not running Windows but Ubuntu)
moonstar-x
  • 268
  • 13
Have you tried formatting it from Ubuntu?
  1. Install gparted: sudo apt-get install gparted
  2. Plug in your USB drive, unmount it in Nautilus (file manager)
  3. Run it from unity, you'll have to give it root access by password
  4. In the top right, select the correct drive. This should be obvious after you check the drive layout for each one and the size
  5. If the drive is OK, then it should list multiple partitions and total size should be 4GB.
  6. Delete all the partitions, reformat them all as one large FAT32 partition
  7. Save the changes
NOTE: You WILL lose all of your data on the drive by following these steps
Nava2
  • 101
