I'm running Ubuntu 11.10 on a virtual host. I've tried upgrading to a newer version by running do-release-upgrade but the process fails with the following error(s).
Err http://ppa.launchpad.net precise/main Translation-en
Err http://ppa.launchpad.net precise/main Sources
Err http://ppa.launchpad.net precise/main amd64 Packages
Err http://ppa.launchpad.net precise/main i386 Packages
  404  Not Found
  404  Not Found
  404  Not Found
Ign http://ppa.launchpad.net precise/main Translation-en
Fetched 0 B in 0s (0 B/s)
Error during update
A problem occurred during the update. This is usually some sort of
network problem, please check your network connection and retry.
W:Failed to fetch
http://ppa.launchpad.net/ferramroberto/java/ubuntu/dists/precise/main/source/Sources
404 Not Found
, W:Failed to fetch
http://ppa.launchpad.net/ferramroberto/java/ubuntu/dists/precise/main/binary-amd64/Packages
404 Not Found
, W:Failed to fetch
http://ppa.launchpad.net/ferramroberto/java/ubuntu/dists/precise/main/binary-i386/Packages
404 Not Found
, E:Some index files failed to download. They have been ignored, or
old ones used instead.
Restoring original system state
Dónal
  • 455
Remove the ppa and update:
sudo sudo add-apt-repository --remove ferramroberto/java
sudo apt-get update
wojox
  • 11,840
