my question is the one which is written in the title.
I installed a program (Teamspeak 3 Client) on my Ubuntu 12.04 LTS Clientversion System. Now I would like to start it in the terminal with the command "teamspeak3". The program is installed in "/opt/teamspeak3/" and I am new on Linux.
So how to create such a command?
So it would be really nice, if someone could help me :)
Thanks a lot!
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
lelelelelelele
  • 357
The answer to your wider question:
  • Create a new file in ~/bin/ (create it if it doesn't exist).
  • Write your script:
    #!/bin/bash
    # do something here.
  • Give that file executable permissions:
    chmod +x ~/bin/filename
In your particular case you could:
  • Symlink the executable into /usr/bin/:
    sudo ln -s /opt/teamspeak3/teamspeak3 /usr/bin/
    This won't always work. Some things behave strangely when symlinked and some things need to be run from the right path... But it's simple and it might work.
  • Or, you could write a little script (as above) but in /usr/bin/ instead of ~/bin/ (you'll need to prepend the commands with sudo)
Oli
  • 299,380
