My question is about how to add a few lines to the /etc/default/grub file so that it is automatically reflected each time /boot/grub/grub.cfg is regenerated. The details:
I'm running ubuntu on a Macbook Pro 8.2 and one of the things that I had to do to get it to run correctly was alter the grub.cfg so that it only loads one of the two graphics cards. To turn off one of the cards I added the text concerning i915 in the GRUB_CMDLINE_LINUX_DEFAULT /etc/default/grub:
GRUB_DEFAULT=0
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i915.lvds_channel_mode=2 i915.modeset=1 i915.lvds_use_ssc=0"
GRUB_CMDLINE_LINUX=""
The problem is that I must also have the following adding to /etc/grub.cfg:
outb 0x728 1
outb 0x710 2
outb 0x740 2
outb 0x750 0
Which I've added in context in grub.cfg as so:
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-1e8685ef-b6a8-4bf3-abb8-62d0212cea7c' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
insmod part_gpt
insmod reiserfs
outb 0x728 1
outb 0x710 2
outb 0x740 2
outb 0x750 0
set root='hd0,gpt4'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt4 --hint-efi=hd0,gpt4 --hint-baremetal=ahci0,gpt4 21c34907-4da5-4356-b1c8-a5d2747411ed
else...
How can I add this to the /etc/default/grub file so that I don't have to manually add it to the grub.cfg every time Ubuntu updates? Currently it appears as if each time Ubuntu updates it regenerates the /boot/grub/grub.cfg file from the /etc/default/grub file and it'd be helpful if these four lines could be included as well.
