I have a bcm4312 broadcom card. When I type iwconfig I have no wireless extensions. I know there is not a problem with my router because other devices connect fine, and my computer connects through ethernet. I had no problem connecting to wifi in 10.10 before I updated today. There is nothing about wireless at all in the network icon. I have tried downloading and installing several drivers but I'm really not sure what I'm doing. I've tried following the directions in all the questions that are similar to mine...
Ash
For some reason, probably a copyright issue, Ubuntu had to remove the firmware for the Broadcom 43* cards from the default install. As a remedy, there are installation packages available. The one for bcm4312 is called "firmware-b43-lpphy-installer". You can install it by using the package manager front-end of your choice (I recommend synaptic), or simply by running the following on command line:
sudo apt-get install firmware-b43-lpphy-installer
After installing it, you should either reload the b43 kernel module, or simply reboot. If your computer does not automatically load the b43 module at reboot after you installed the firmware, you can try to load it manually by running (in a terminal)
sudo modprobe b43
If manual loading works, you can add a line saying "b43" to /etc/modules (you need to edit this file as root for instance by running "sudo gedit /etc/modules" on the terminal) to force Ubuntu to load it at boot.
If that doesn't work, you can also try "firmware-b43-installer".
soulsource
  • 5,034
