I have ubuntu 12.10 and I can't play dvd movies. I tried every kmplayer vlc gnomeVLC could not read the file (Input/output error).
File reading failed:
Your input can't be opened:
VLC is unable to open the MRL 'dvd:///media/ahsidddiqui/Ubuntu%20OEM%2012.10%20amd64%20UALinux/'. Check the log for details.
This might be caused by not having the correct codecs installed. To be able to play DVDs on Ubuntu, there are a few things you need to do first:
  1. Install ubuntu-restricted-extras, either through the software center or the terminal using the following command: sudo apt-get install ubuntu-restricted-extras
  2. Install libdvdcss using the following command in the terminal: sudo /usr/share/doc/libdvdread4/install-css.sh
You can read more about playing DVDs on the Community Help Wiki
ananaso
  • 4,080
  • 32
  • 52
For Ubuntu 16.04 i needed to do some more. I needed to install libdvdread4 and libdvdcss The first one can be installed through apt. For the latter one the installation steps are written in detail in /usr/share/doc/libdvdread4/README.css or here. After adding these two libs i was able to play original dvd`s on my laptop.
theDrifter
  • 111
You need Medibuntu for this - here is documentation - what to do :
https://help.ubuntu.com/community/Medibuntu
dschinn1001
  • 3,863
