I want to install the decentralized YaCy web search engine, but could not find a way to do this on Ubuntu 13.04.
Which steps do I need to perform to install YaCy?
This is how I got it working:
./startYACY.sh" file the easiest way to run this is just to open terminal and drag and drop this file into it and press enter. It will tell you that
"YaCy started as daemon process. Administration" and an HTTP address just copy the address and paste it into the web browserAll this can be done by running in a terminal:
sudo apt-get update
sudo dpkg --configure -a
sudo apt-get install -y openjdk-8-jre-headless
wget http://latest.yacy.net/yacy_v1.922_20191013_9964.tar.gz
tar xfz yacy_v1.922_20191013_9964.tar.gz
cd yacy
./startYACY.sh
Then open http://localhost:8090 in your web-browser.
Good luck
There is now a Debian/Ubuntu repository available. In Synaptic Package Manager, add the following apt-line (repository link):
deb http://debian.yacy.net ./
Register the YaCy repository key:
sudo apt-key advanced --keyserver pgp.net.nz --recv-keys 03D886E7
Update your repositories and install:
sudo apt-get update
sudo apt-get install openjdk-7-jre-headless #only a headless version is needed
sudo apt-get install yacy
YaCy should now be available at http://localhost:8090 - it will ask you to configure some settings there.
You only need to set an admin password if you want access to admin configuration from remote machines, or local password protection. Otherwise admin configuration is only accessible from localhost (without a password).
(Note that YaCy will now be running in the background all the time.)
You will automatically receive updates when they are made to the repository, just like other Ubuntu updates.
Reference: http://www.yacy-websuche.de/wiki/index.php/En:DebianInstall
