i used to use 12.04 LTS and had the same problem..upgraded to 12.10 as i have read somewhere that 12.10 has a fix for it...but i still face the same problem.. *i have wvdial...usb-mode switch packages *my modem also shows up in lsusb command *i have added my modem under the mobile broadband tab of network settings *enabled networking in recovery mode
NOTE:-when i boot up in the recovery mode..the option is available in the network settings to "ENABLE BROADBAND" and also my modem shows up and i am able to connect it...but i am unable to do so in the normal boot.
p.s:- i use tata photon +
You may try this:
Press ALT+F2 and enter gksu gedit /etc/udev/rules.d/yourtataphoton.rules to create the file we need. Now paste the content below into the file and save it.
SUBSYSTEM="usb"
SYSFS{idProduct}="1446"
SYSFS{idVendor}="12d1"
RUN+="/lib/udev/modem-modeswitch --vendor 0x12d1 --product 0x1446 --type option-zerocd"
Now just plug in your dongle and configure your connection using NetworkManager.
Source
karan
  • 333
I've got a Sony P11Z netbook with a built-in USB 3G Modem and i'm using debian, maybe my problem is the same as yours.
# lsusb -s 001:007
Bus 001 Device 007: ID 0af0:7601 Option Globetrotter MO40x 3G Modem (GTM 382)
When booting a 3.10 kernel the mobile broadband option usually is missing (but not always). When i boot a 3.2 kernel it shows up again (most often).
I checked /var/log/syslog while restarting network-manager and found these 3 lines:
Dec  4 08:31:18 plok NetworkManager[4934]: <info> rfkill0: found WiFi radio killswitch (at /sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/device:17/SNY5001:00/rfkill/rfkill0) (platform driver Sony Notebook Control Driver)
Dec  4 08:31:18 plok NetworkManager[4934]: <info> rfkill2: found WWAN radio killswitch (at /sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/device:17/SNY5001:00/rfkill/rfkill2) (platform driver Sony Notebook Control Driver)
Dec  4 08:31:18 plok NetworkManager[4934]: <info> rfkill3: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.1/0000:02:00.0/ieee80211/phy0/rfkill3) (driver ath9k)
Now i found out that, in my case, issuing the following command would bring up the device, regardless of the currently running kernel. It takes a few seconds to initialize (follow the process with tail -f /var/log/syslog), then the "mobile broadband" option would show up in gnome-network-manager.
echo 1 > /sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/device:17/SNY5001:00/rfkill/rfkill2/state
sillyslux
  • 111
