I downloaded and try to installed the package "wfconvert" from this link . but I got some error.
here what I did:
- copy the wfconvert folder in root "/"
cd /wfconvert/build/root@geant4:/wfconvert/build# cmake .. -- Current revision : 65 modified on 2013-01-16 22:14:53 +0330 (Wed, 16 Jan 2013) -- Found mpi.h and libraries. Check for working mpi compiler -- MPI is disabled -- Failed to link LAPACK, BLAS, ATLAS libraries with environments. Going to search standard paths. -- LAPACK_LIBRARIES=/usr/lib/liblapack.so -- BLAS_LIBRARIES=/usr/lib/libblas.so -- CXX compiler flags: -g -O3 -ftemplate-depth-60 -Drestrict=__restrict__ -funroll-all-loops -finline-limit=1000 -Wno-deprecated -mmmx -msse -msse2 -msse3 -fopenmp -- CC compiler flags: -O3 -Drestrict=__restrict__ -funroll-all-loops -finline-limit=1000 -std=gnu99 -fomit-frame-pointer -mmmx -msse -msse2 -msse3 -- LIBXML2_INCLUDE_DIR=/usr/include/libxml2 -- LIBXML2_LIBRARIES=/usr/lib/libxml2.so -- HDF5_INCLUDE_DIR=/usr/include -- HDF5_LIBRARIES=/usr/lib/libhdf5.so -- FFTW_INCLUDE_DIR=/usr/include -- FFTW_LIBRARIES=/usr/lib/libfftw3.so -- Ready to build qmcpack -- Configuring done -- Generating done -- Build files have been written to: /wfconvert/buildmake command
root@geant4:/wfconvert/build# make [ 1%] Building C object src/einspline/CMakeFiles/einspline.dir/bspline_create.c.o In file included from /wfconvert/src/einspline/bspline_base.h:24:0, from /wfconvert/src/einspline/bspline_create.h:24, from /wfconvert/src/einspline/bspline_create.c:21: /wfconvert/build/src/Common/config.h:65:17: fatal error: cmath: No such file or directory #include <cmath> ^ compilation terminated. make[2]: *** [src/einspline/CMakeFiles/einspline.dir/bspline_create.c.o] Error 1 make[1]: *** [src/einspline/CMakeFiles/einspline.dir/all] Error 2 make: *** [all] Error 2
I don`t know what to do!
here is my cmath file list:
root@geant4:/# find -name cmath
./opt/root5.32.00/cint/cint/include/cmath
./app/gcc/4.8.0/include/c++/4.8.0/ext/cmath
./app/gcc/4.8.0/include/c++/4.8.0/cmath
./app/gcc/4.8.0/include/c++/4.8.0/tr1/cmath
./usr/include/boost/compatibility/cpp_c_headers/cmath
./usr/include/boost/tr1/tr1/cmath
./usr/include/c++/4.5/cmath
./usr/include/c++/4.5/tr1_impl/cmath
./usr/include/c++/4.5/tr1/cmath
./usr/include/c++/4.6/cmath
./usr/include/c++/4.6/tr1/cmath
./usr/share/gccxml-0.9/GCC/2.95/cmath
./gcc-build/gcc-4.8.0/stage1-i686-pc-linux-gnu/libstdc++-v3/include/ext/cmath
./gcc-build/gcc-4.8.0/stage1-i686-pc-linux-gnu/libstdc++-v3/include/cmath
./gcc-build/gcc-4.8.0/stage1-i686-pc-linux-gnu/libstdc++-v3/include/tr1/cmath
./gcc-build/gcc-4.8.0/i686-pc-linux-gnu/libstdc++-v3/include/ext/cmath
./gcc-build/gcc-4.8.0/i686-pc-linux-gnu/libstdc++-v3/include/cmath
./gcc-build/gcc-4.8.0/i686-pc-linux-gnu/libstdc++-v3/include/tr1/cmath
./gcc-build/gcc-4.8.0/libstdc++-v3/include/ext/cmath
./gcc-build/gcc-4.8.0/libstdc++-v3/include/c/cmath
./gcc-build/gcc-4.8.0/libstdc++-v3/include/c_global/cmath
./gcc-build/gcc-4.8.0/libstdc++-v3/include/c_std/cmath
./gcc-build/gcc-4.8.0/libstdc++-v3/include/tr1/cmath
./gcc-build/gcc-4.8.0/libstdc++-v3/testsuite/26_numerics/headers/cmath
./gcc-build/gcc-4.8.0/libstdc++-v3/testsuite/tr1/8_c_compatibility/cmath
./gcc-build/gcc-4.8.0/prev-i686-pc-linux-gnu/libstdc++-v3/include/ext/cmath
./gcc-build/gcc-4.8.0/prev-i686-pc-linux-gnu/libstdc++-v3/include/cmath
./gcc-build/gcc-4.8.0/prev-i686-pc-linux-gnu/libstdc++-v3/include/tr1/cmath
and
root@geant4:/# uname -a
Linux geant4 3.0.0-32-generic-pae #51-Ubuntu SMP Thu Mar 21 16:09:48 UTC 2013 i686 i686 i386 GNU/Linux
Please help me.
