I tried to add a textlayer to some pdf files in order to make them searchable. This technique is explained in the german Ubuntu wiki: http://wiki.ubuntuusers.de/pdfsandwich . After installing dependencies
sudo apt-get install imagemagick exactimage ghostscript tesseract-ocr
and pdfsandwich itself it should be as simple as
pdfsandwich test.pdf
However I get:
Input file: "test.pdf"
Output file: "test_ocr.pdf"
Number of pages in inputfile: 272
Parallel processing with 8 threads started.
Processing page order may differ from original page order.
Processing page 137.
Processing page 171.
Processing page 1.
PProcessing page Processing pProcessing page rocess35.
age 239.
Processing page 69.
205.
ing page 103.
sh: 1: cannot open /tmp/pdfsandwich4e375e.html: No such file
followed by many more cannot open ... warnings. Inspection of my /tmpdirectory shows that instead of these *.html files the corresponding *.txt files exist. Seemingly tesseract does not output in hocr format. I read the man pages of tesseract and tried to enforce hocr output by creating a config file named tesseract-config
hocr true
(I tried various variations thereof) and starting pdfsandwich with
pdfsandwich -tesso tesseract-config test.pdf
But this does not seem to change anything. Any ideas how I can make pdfsandwich produce proper output?
Note the related questions How to add OCRed text to original pdf in gscan2pdf? and Adding OCR info to a PDF . However I need to process many pdf files and therefore I need a command-line solution which I can automate.
It turned out that the format of the config file changed with the present ubuntu version of tesseract (3.02.01): http://code.google.com/p/tesseract-ocr/source/browse/trunk/tessdata/configs/hocr?r=526 . Tesseract can now be instructed to output in hocr format with a single line configuration file tesseract-config:
tessedit_create_hocr 1
As noted in the question, tesseract can be instructed to read the config file by passing the -tesso option to pdfsandwich:
The reason for this error is that tesseract changed its default file extensions for hocr, making it incompatible with pdfsandwich <0.1.0. For tesseract 3.02 with pdfsandwich <0.1.0, it helps to modify the tesseract option file and to pass it to pdfsandwich with -tesso.
Tesseract 3.03, which is the default tesseract version in Ubuntu 14.04, substantially changed its hocr handling, making it partially incompatible with hocr2pdf, so that the "-tesso" fix will often result in text layers which do not fit to the scanned images. Instead, not hocr2pdf but tesseract itself needs to be used to produce each single page of pdf files.
Pdfsandwich >=0.1.0 automatically recognizes the tesseract version and chooses the appropriate way of interaction with tesseract, so that all these errors do not occur anymore.
