Burning data CD using brasero get stuck at 100% and the dialog box only show Creating image checksum, empty progress bar, and a cancel button, and the disk is not spinning anymore in my cd writer. Simply click cancel will make the cd blank, i have try with some new an used CD-RW disc but stilk no luck. I'm on Raring.
Asked
Active
Viewed 2.4k times
First solution:
Just disable the checksum: Open Brasero > Edit > Plugins > Uncheck Image Checksum.
Second solution:
Install cdrdao and this should solve the problem. Unfortunately, it can't solve it in the middle of the burning process.
sudo apt-get install cdrdao
David Foerster
- 36,890
- 56
- 97
- 151
valk
- 417
k3b has been a standard on my machines for over a decade. It just works (TM). I was having the same problem with Brasero/gnome CD creator and just installed it. Problem solved.
The nice thing about Linux is it doesn't really matter what desktop/native environment you have, you can use applications from others. apt/yum will install all the needed libraries.
Michael Adams
- 23
- 3
