How do we install cinnamon in Ubuntu raring? I added deb http://packages.linuxmint.com/ debian main import backport upstream romeo to the sources list and used apt-get update to update the sources.
The result was :
Fetched 523 kB in 1h 0min 24s (144 B/s)
Reading package lists... Done
W: GPG error: http://packages.linuxmint.com debian Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 3EE67F3D0FF405B2
Next, I tried installing cinnamon as follows, I get errors...
$ sudo apt-get install cinnamon nemo
[sudo] password for roshan:
Building dependency tree
 cinnamon : Depends: gir1.2-muffin-3.0 but it is not going to be installed
            Depends: libcogl-pango0 (>= 1.7.4) but it is not installable
            Depends: libcogl9 (>= 1.9.6) but it is not installable
            Depends: libgjs0b (>= 1.32.0) but it is not installable
            Depends: libgnome-desktop-3-2 (>= 3.2.0) but it is not installable
            Depends: libmuffin0 but it is not going to be installed
            Recommends: gnome-themes-standard but it is not going to be installed
            Recommends: cinnamon-screensaver but it is not going to be installed
            Recommends: gir1.2-gjsdbus-1.0 but it is not installable
 nemo : Depends: libgnome-desktop-3-2 (>= 3.2.0) but it is not installable
        Recommends: nemo-fileroller but it is not going to be installed
How to correct this?
