I copied the ISO file and tried to boot from USB to install Ubuntu 13.04. Didn't work :( then tried after all the files in the ISO image copied to the USB stick. Also didn't work "Missing operation system" was the message I've installed Ubuntu 12.04 alongside of Windows Vista and I've removed it. Thank you
Asked
Active
Viewed 1,935 times
You tried to create the bootable usb with universal application like usb-installer?
http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
agentehule
- 31
- 1
- 4
To make a USB stick to a boost device.It should be use tools make it a bootable device. For example ISO file, you could use linux command
dd if=**.iso of=/dev/sdb BS=1M
**.iso is the system image
/dev/sdb is the usb device
syler
- 56
- 1
