34
Ubuntu 10.04
I have created this upstart script (/etc/init/pure-ftpd.conf):
# pure-ftpd - FTP server
description "Pure-FTPd server"
start on filesystem
stop on runlevel S
respawn
respawn limit 10 5
pid file /var/run/pure-ftpd.pid
console output
pre-start script
    test -x /usr/local/sbin/pure-ftpd || { stop; exit 0; }
end script
exec /usr/local/sbin/pure-ftpd --maxclientsnumber 2 --maxclientsperip 10 --prohibitdotfileswrite --prohibitdotfilesread --noanonymous --chrooteveryone --dontresolve --nochmod --pidfile /var/run/pure-ftpd.pid
But...
# start pure-ftpd
start: Unknown job: pure-ftpd
and
# service pure-ftpd start
What's the problem?
Is it necessary to do something more?
Is it necessary to create one script in /etc/init.d too?
muru
  • 207,228
Juan Simón
  • 1,703
6 Answers6
46
You can also run init-checkconf to check syntax
init-checkconf /etc/init/job.conf
File /etc/init/job.conf: syntax ok
27
It usually means you have an error in the .conf file - for instance I'm not sure the pid stanza is supported in 10.04, stop can't be used in the script etc.
I'd try starting the file from scratch (with only start, stop etc), and then slowly building it up by adding more and more lines and testing it via start pure-ftpd.
For example:
# cat pure-ftpd.conf
start on filesystem
stop on runlevel S
respawn
respawn limit 10 5
# start pure-ftpd
pure-ftpd start/running
start on filesystem
stop on runlevel S
respawn
respawn limit 10 5
# start pure-ftpd
arrange
  • 15,219
26
First, you can check that your job is actually known to upstart:
sudo initctl list | grep your_job_name
...where your_job_name is the name of your upstart script minus the .conf extension.
If it's not found, you can try reloading the configuration and then re-checking:
sudo initctl reload-configuration
# re-check
Then try again to start your job:
sudo start your_job_name
If you weren't getting any logging in /var/log/daemon.log or /var/log/syslog before, you might have some now.
Madbreaks
  • 128
The most relevant reference for job file syntax will be available when you run the command:
man 5 init
on your system. For Ubuntu 10.04, as you found in the previous answer, the pid file syntax is incorrect.
Any time you get that 'unknown job" error back, its a good idea to check the logs (pre 11.04, /var/log/daemon.log, 11.04 and greater everything goes in /var/log/syslog)
You may see an error like this:
init: /etc/init/test.conf:2: Unknown stanza
SpamapS
  • 20,110
Anyway I'am here because i had the same problem, but my syntax was 100% correct.
After some debugging I discovered another issue that can cause this "Unknown job" error:
upstarts uses inotify to monitor .conf file changes and auto install jobs, this is very cool (for this you don't need something like update.rc with upstart!) but can be not perfect if you (like me in that case) use some FTP/SCP GUI program to upload and edit configurations on remote servers, the job can be silently uninstalled by upstart when you edit file in that manner.
to fix simply do that (that saved me)
touch /etc/init/*
it will generate inotify events to refresh all upstart confs.
I had the same problem in my Ubuntu 14.04 Docker containers. As it turns out, the Ubuntu 14.04 image (if not others) for Docker does not support Upstart in the same way that a full virtual machine would.
To answer this question, why the service does not start, it is because initctl is not an actual Upstart program: it is mapped to /bin/true.
To verify run the following on a Ubuntu 14.04 Docker container vs. Vagrant, and vs. a DigitalOcean droplet
$ ls -al /sbin/initctl
You'll see initctl is not the same in Docker vs. the others.
A link that may further your understanding.. https://github.com/docker/docker/issues/1024
