I downloaded Eclipse Juno package, and extracted it to /opt directory. For installing it, I followed the steps given in this site - Ubuntu Help under the User Installation section. I created the opt_eclipse.desktop file in /usr/share/applications/ directory. Here is the content of my desktop file:
[Desktop Entry]
Type=Application
Name=Eclipse
Comment=Eclipse Integrated Development Environment
Icon=eclipse
Exec=eclipse42
Terminal=false
Categories=Development;IDE;Java;
StartupWMClass=Eclipse
X-Desktop-File-Install-Version=0.20
Then I installed the desktop file on Unity using the following command, as given in this post:
sudo desktop-file-install /usr/share/applications/opt_eclipse.desktop
Then I created the symbolic link using the below command:
sudo ln -s /opt/eclipse/eclipse /usr/local/bin/eclipse42
I also moved the icon to the pixmaps folder using the below command:
cp opt/eclipse/icon.xpm /usr/share/pixmaps/eclipse.xpm
Now, when I go to Unity, I can find the Eclipse Icon. But, when I click it, nothing happens. It doesn't get started. I'm completely new to Ubuntu. Did I miss something out there?
Did you also install the jdk, it is needed for eclipse.
Enter the full path to the start-script in the Desktop-file
Exec=/path/to/ecplipse/eclipse42
if the path is noch included in your $PATH-Variable, what normally should note be if you did not by yourself.
herrhansen
  • 251
I think you need JAVA Runtime Environment installed. Did you try running eclipse directly by clicking binary?
Misery
  • 3,534
