Well i have an old eMac and i wanted to replace the operating system with Ubuntu but I don"t want to break it.
user166755
It doesn't require much to run, (500 MB) but it will be slow. you will need around (1-2 GB to have a smoother system), but this is up to every user what they can handle.
I would try lubuntu or Xubuntu on an old Emac.
Try with the live-CD first so you know ruffly how fast the system will be. The CD will be slower than a hard drive but it will give a hint on which system will be fastest.
For more info check this question:
Alvar
  • 17,038
It depends also on what distribution you want to use or what you should use
Basically, older distros are fine for older pc's and newer ones for newer pc's. Example... why don't you try Karmic Koala?
Diego Jp
  • 31
