I created a flash drive with 12.04 Ubuntu on it, because I want to try it and explore it. I can't get my computer to boot from the drive. I used the suggested pendrive program to format the drive. I opened my boot menu when i started my computer and it didn't have the option to boot from the flash drive. Is there anything I can do or should I just give up and burn it to a disk?
Asked
Active
Viewed 3,767 times
You might have to enable the option in the BIOS. It should be pretty obvious once you get into the BIOS. This guide http://pcsupport.about.com/od/fixtheproblem/ht/accessbios.htm looks alright.
I may be able to help if you were to provide more information.
Bardi Harborow
- 115
- 7
If your BIOS doesn't have the option to boot from USB as suggested here, some BIOS versions will enumerate USB block devices under hard disk boot options (I've seen this on Gigabyte mainboards) and you can find the make and model of your flash drive to boot from there. If that isn't your situation you should go ahead and burn the ISO to an optical disk and boot from that.
Elder Geek
- 36,752
