I can't seem to upgrade to the latest version ubuntu. It asked me once, but I was doing something else at the time. Now that I ant to do it I can't find it. I can find software updater, but that just seems to update programs that are on the computer.
Asked
Active
Viewed 1.1k times
Click on the Gear on the top-right corner> System Settings...>Software&Updates there go to the Updates Tab and then check that "Notify me of a new Ubuntu version is set to: For any version. then execute the Software updater and it should tell you (if not hit refresh) Hope it helps
Axter
- 41
-1
Click Alt + F2 and type update-manager at the prompt or do the same in Terminal.
If this does not show the update open a Terminal window and type in
sudo apt-get update
sudo apt-get upgrade
The sudo apt-get upgrade command updates any installed software requiring an update before you proceed
sudo do-release-upgrade
This searches for and upgrades your system
How to safely upgrade from an older Ubuntu version to a newer one? Is the best and safest way.
Edited with corrections suggested below
