How can I install .run files?
When I open them with the software center, I always get the message that the file couldn't be opened.
.run files usually are scripts. You should not install - execute any file - script outside of Ubuntu repositories, except if you trust 100% the source. You can see the contents of the .run file with an editor.
gedit <filename>.run
You can execute a .run file from terminal (CTRL+ALT+T). First give the appropriate permissions. You have to connect to folder where the file is. I assume is in Downloads folder
cd Downloads
chmod +x <filename>.run
Then execute it with
./<filename>.run
or if needs root privileges (dangerous) , prefix with sudo
NickTux
  • 17,865
  • 57
  • 66
