I searched for that, but did not find any reference to it on this site. If you know some, please refer me to it - the issues I have seen have different symptoms. So, to the point...
I had Ubuntu 12.04 LTS for a long time, switched to Ubuntu Gnome Shell etc. Recently I wanted to move to Ubuntu 13.04 and found an issue that seemingly occurred previously, but at seemingly random rate. Now I cannot start Ubuntu Software Center at all.
When I run the console I see:
$ software-center
(process:22270): Gtk-WARNING **: Locale not supported by C library.
    Using the fallback 'C' locale.
Traceback (most recent call last):
  File "/usr/bin/software-center", line 36, in <module>
    from softwarecenter.utils import (
  File "/usr/share/software-center/softwarecenter/utils.py", line 47, in <module>
    from config import get_config
  File "/usr/share/software-center/softwarecenter/config.py", line 33, in <module>
    class SoftwareCenterConfig(object, SafeConfigParser):
  File "/usr/lib/python2.7/abc.py", line 87, in __new__
    cls = super(ABCMeta, mcls).__new__(mcls, name, bases, namespace)
TypeError: Error when calling the metaclass bases
    Cannot create a consistent method resolution
order (MRO) for bases SafeConfigParser, object
I hoped that following these ideas (source) could be helpful:
$ sudo apt-get purge software-center
$ sudo apt-get update
$ sudo apt-get dist-upgrade
$ sudo apt-get install software-center
$ sudo dpkg-reconfigure software-center --force
It was not:
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  software-center-aptdaemon-plugins
Use 'apt-get autoremove' to remove it.
The following packages will be REMOVED:
  software-center*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? Y
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LANG = "en_US.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
(Reading database ... 269627 files and directories currently installed.)
Removing software-center ...
Purging configuration files for software-center ...
rmdir: failed to remove `/var/cache/software-center/xapian/': No such file or directory
dpkg: error processing software-center (--purge):
 subprocess installed post-removal script returned error exit status 1
 software-center
What am I doing wrong? How can I get rid of Ubuntu Software Center causing error and install version that will not have that?
Or maybe the problem is with my Python interpreter?
$ python --version
Python 2.7.3
I believe Ubuntu is gradually moving to tools working on Python 3.x only, but is that the cause?
Thanks for all the tips. I strongly believe it may be also helpful for the others.
Update 1.:
The first update went from 12.04 to 12.10, and I did not notice it did not reach 13.04. As soon as I noticed, I upgraded from 12.10 to 13.04. The problem however did not disappear.
I also did what thefourtheye asked:
$ sudo locale-gen
Generating locales...
  en_US.UTF-8... up-to-date
Generation complete.
And this is the result of trying to do the purge:
The following packages were automatically installed and are no longer required:
  python-oneconf software-center-aptdaemon-plugins
Use 'apt-get autoremove' to remove them.
  software-center*
(Reading database ... 279036 files and directories currently installed.)
rmdir: failed to remove ‘/var/cache/software-center/xapian/’: No such file or directory
No apport report written because MaxReports is reached already
 software-center
Update 2.:
Another debug information (requested by nickguletskii):
$ cat /etc/environment
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
and
$ sudo apt-get install language-pack-en
The following extra packages will be installed:
  firefox-locale-en language-pack-en-base
The following NEW packages will be installed:
  firefox-locale-en language-pack-en language-pack-en-base
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,372 kB of archives.
After this operation, 4,874 kB of additional disk space will be used.
Get:1 http://security.ubuntu.com/ubuntu/ raring-security/main firefox-locale-en amd64 21.0+build2-0ubuntu0.13.04.2 [549 kB]
Get:2 http://archive.ubuntu.com/ubuntu/ raring/main language-pack-en-base all 1:13.04+20130418 [822 kB]
Get:3 http://archive.ubuntu.com/ubuntu/ raring/main language-pack-en all 1:13.04+20130418 [1,968 B]
Fetched 1,372 kB in 2s (521 kB/s)
Selecting previously unselected package language-pack-en-base.
(Reading database ... 279503 files and directories currently installed.)
Unpacking language-pack-en-base (from .../language-pack-en-base_1%3a13.04+20130418_all.deb) ...
Selecting previously unselected package language-pack-en.
Unpacking language-pack-en (from .../language-pack-en_1%3a13.04+20130418_all.deb) ...
Selecting previously unselected package firefox-locale-en.
Unpacking firefox-locale-en (from .../firefox-locale-en_21.0+build2-0ubuntu0.13.04.2_amd64.deb) ...
Processing triggers for software-center ...
ERROR:root:DebFileApplication import
  File "/usr/share/software-center/softwarecenter/db/__init__.py", line 4, in <module>
    from debfile import DebFileApplication, DebFileOpenError
  File "/usr/share/software-center/softwarecenter/db/debfile.py", line 25, in <module>
    from softwarecenter.db.application import Application, AppDetails
  File "/usr/share/software-center/softwarecenter/db/application.py", line 28, in <module>
    import softwarecenter.distro
  File "/usr/share/software-center/softwarecenter/distro/__init__.py", line 26, in <module>
    from softwarecenter.utils import UnimplementedError, utf8
  File "/usr/share/software-center/softwarecenter/utils.py", line 48, in <module>
order (MRO) for bases object, SafeConfigParser
  File "/usr/sbin/update-software-center", line 38, in <module>
    from softwarecenter.db.update import rebuild_database
  File "/usr/share/software-center/softwarecenter/db/update.py", line 33, in <module>
    from softwarecenter.backend.scagent import SoftwareCenterAgent
  File "/usr/share/software-center/softwarecenter/backend/scagent.py", line 28, in <module>
    from softwarecenter.distro import get_distro, get_current_arch
Setting up firefox-locale-en (21.0+build2-0ubuntu0.13.04.2) ...
Setting up language-pack-en (1:13.04+20130418) ...
Setting up language-pack-en-base (1:13.04+20130418) ...
  en_AG.UTF-8... done
  en_AU.UTF-8... done
  en_BW.UTF-8... done
  en_CA.UTF-8... done
  en_DK.UTF-8... done
  en_GB.UTF-8... done
  en_HK.UTF-8... done
  en_IE.UTF-8... done
  en_IN.UTF-8... done
  en_NG.UTF-8... done
  en_NZ.UTF-8... done
  en_PH.UTF-8... done
  en_SG.UTF-8... done
  en_ZA.UTF-8... done
  en_ZM.UTF-8... done
  en_ZW.UTF-8... done
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf-2.index...
Update 3.:
After following advice of nickguletskii I am getting this:
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LANGUAGE="en_US:en_US:en"
LANG="en_US.UTF-8"
$ software-center
  software-center*
After this operation, 3,588 kB disk space will be freed.
(Reading database ... 280103 files and directories currently installed.)
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for man-db ...
 software-center
  software-center
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/442 kB of archives.
After this operation, 3,588 kB of additional disk space will be used.
Selecting previously unselected package software-center.
(Reading database ... 279639 files and directories currently installed.)
Unpacking software-center (from .../software-center_5.6.0-0ubuntu3_all.deb) ...
Setting up software-center (5.6.0-0ubuntu3) ...
$ software-center
Seemingly locale-related errors went away, but I still cannot run Ubuntu Software Center, even after attempt to reinstall it.
Update 4.:
After reinstalling some Python stuff and correcting order of base classes for SoftwareCenterConfig, I am getting this:
$ software-center
2013-06-09 14:24:06,002 - softwarecenter.ui.gtk3.app - INFO - setting up proxy 'None'
2013-06-09 14:24:06,283 - softwarecenter.fixme - WARNING - logs to the root logger: '('/usr/lib/python2.7/dist-packages/dbus/proxies.py', 410, '_introspect_error_handler')'
2013-06-09 14:24:06,283 - dbus.proxies - ERROR - Introspect error on com.ubuntu.sso:/com/ubuntu/sso/credentials: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.Spawn.ChildExited: Process /usr/lib/ubuntu-sso-client/ubuntu-sso-login exited with status 1
  File "/usr/bin/software-center", line 130, in <module>
    app = SoftwareCenterAppGtk3(options, args)
  File "/usr/share/software-center/softwarecenter/ui/gtk3/app.py", line 338, in __init__
    self.icons)
  File "/usr/share/software-center/softwarecenter/ui/gtk3/session/appmanager.py", line 66, in __init__
    self.oauth_token = helper.find_oauth_token_sync()
  File "/usr/share/software-center/softwarecenter/backend/ubuntusso.py", line 141, in find_oauth_token_sync
    sso.find_credentials()
  File "/usr/share/software-center/softwarecenter/backend/login_impl/login_sso.py", line 75, in find_credentials
    self.proxy.find_credentials(self.appname, self._get_params())
  File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 70, in __call__
    return self._proxy_method(*args, **keywords)
  File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 145, in __call__
    **keywords)
  File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
Tadeck
  • 252
TL;DR:
The following fixed it for me:
sudo chmod -r 755 /usr/local/lib/python2.7/dist-packages/
and
sudo reboot
My debugging path
I'm experiencing the same issues with ubuntuone and software-centre. These are the following steps I took to further debug this issue:
U1_DEBUG=True /usr/lib/ubuntu-sso-client/ubuntu-sso-login
which led to the following output:
  File "/usr/lib/ubuntu-sso-client/ubuntu-sso-login", line 67, in <module>
    from ubuntu_sso.main import main
  File "/usr/lib/python2.7/dist-packages/ubuntu-sso-client/ubuntu_sso/main/__init__.py", line 39, in <module>
    from twisted.internet import defer
  File "/usr/lib/python2.7/dist-packages/twisted/__init__.py", line 53, in <module>
    _checkRequirements()
  File "/usr/lib/python2.7/dist-packages/twisted/__init__.py", line 40, in _checkRequirements
    raise ImportError(required + ".")
ImportError: Twisted requires zope.interface 3.6.0 or later.
I then installed the zope.interface :
sudo easy_install zope.interface
I've tried it out in the python interpreter:
>>> import zope.interface
and got a few "Permission denied" errors on the Python packages:
IOError: [Errno 13] Permission denied: '/usr/local/lib/python2.7/dist-packages/httplib2-0.8-py2.7.egg/EGG-INFO/top_level.txt'IOError: [Errno 13] Permission denied: '/usr/local/lib/python2.7/dist-packages/httplib2-0.8-py2.7.egg/EGG-INFO/top_level.txt'
after which I decided to change access permissions to the file:
which resulted in the GUI of Ubuntu One to pop and attempt to sync. Only to receive a dBus exception afterwards in a pop-up window. At least the GUI started working...
For Software Centre, I ran the following command in the terminal:
software-center --debug
got a few more of the same dBus exceptions and googling the issue I found out that a restart suffice it for the exceptions to go away which are triggered due to a timeout.
b06
  • 73
It looks like your /etc/environment does not contain the language settings. You need to append the following lines to /etc/environment:
LANG="en_US.UTF-8"
and reboot. Just sudo nano /etc/environment, End, Ctrl + Shift + V, Ctrl + X, Y.
