Using Qt Creator 2.7.0, when I switch to design view of a qml file, I'm now getting 3 additional, unresponsive windows opening up, all with the title “Qml2Puppet”. This didn't used to happen.
I've un-installed and re-installed Qt Creator (using sudo apt-get purge qtcreator and sudo apt-get install qtcreator), but this hasn't solved it. I've also deleted the QtProject.conf, Trolltech.conf and QtProject items in ~/.config.
Any ideas for what else to try? I'm using Kubuntu 13.04, 64 bit.
Note: this is a different issue to Multiple Windows at QtCreator startup (where the windows are untitled and appear at startup).
Simonski
  • 275
Yes, annoying. I hope, soon, it is fixed. Waiting is annoying also?
Well, actually, I have a workaround on this. Fortunately, clicking on "design" tab launching qml2puppet executable located on /usr/bin.
By this mechanism, we can substitute the qml2puppet executable with our own script. The script will execute the real qml2puppet and beside, suppressing the "ilegal" windows.
Steps :
  1. Rename qml2puppet into qml2puppet.bak
    sudo mv /usr/bin/qml2puppet /usr/bin/qml2puppet.bak
  2. Make our executable script
    • Create file
      gksudo gedit /usr/bin/qml2puppet
    • Copy the full-script here into the script
    • Make it executable
      sudo chmod a+x /usr/bin/qml2puppet
  3. Download script component for controlling windows : wmctrl
    sudo apt-get install wmctrl
  4. Well done. Try it! When you face other problem following those step, you can comment below.
Abdillah
  • 666
