I have been troubleshooting my HP EliteBook with BCM4322 14e4:432b wireless card. I am using Linux kernel 3.9 and I have almost found the solution. Reading on the Linux Wireless site, I found that the b43 and wl drivers should work at least somewhat with the card. I was unable to get things working using kmod-wl, and so I moved on to working with b43. I followed the guide here, and got it working using these lines of code:
modprobe -r b43 bcma
modprobe -r brcmsmac bcma
modprobe -r wl
modprobe b43
When I restart the computer, I have to do this again to get things working. I know I am supposed to blacklist the unwanted modules, but adding brcmsmac and wl to the blacklist.conf file does not seem to work. How can I get this to work permanently?
If the blacklisting does not work then the module might be loaded early in the initframfs. Take a look at the file /etc/initramfs-tools/modules.
What is the content of /etc/modules? Also please post the lines you used to blacklist the modules.
br
Update:
I found the following command on the b43 homepage:
sudo apt-get install firmware-b43-installer
Have you tried that?
On the other hand, if you want to have your module loaded at run-time, add the following line to /etc/modules:
b43
to /etc/modprobe.d/blacklist.conf
blacklist brcmsmac and blacklist wl
then reboot the machine.
The module should be loaded then.
ortang
  • 2,183
  • 14
  • 13
